clutch noise
DomP182
Car  ph1 172, Arctic182
When I am pulling off I occasionally get a grind noise which I can feel through the clutch pedal. My car has only done 40k and the clutch doesnt seem to be slipping, any ideas?
Fairly, it'll get worse over the next 5-6k.
Noise go away when clutch is pressed?
Mine doenst sound like a clutch bearing, just a light grinding noise along with vibrations through the pedal when releasing the clutch, past the biting point.
So just after when the clutch pedal comes up? So the sound goes when full pressed?
yes when the clutch comes up and the car moves in 1st gear
no noise at all if in neutral gear, engaging and disengaging is totally silent.
the car s ok, and the clutch works fine through out the gears, just the odd time when you get the short grind noise/vibration in first gear as soon as the car pulls after the biting point.
If there s just a cable between you and the clutch, I cant help thinking something is wrong with the clutch or with the self adjuster wearing teeth and sliding down.
Well in mine if on a flat and I just lift the clutch with no throttle I wont get the noise. Definately dont get it on depressing the clutch. Its a definite grumble/grind if I put my right foot down a little bit?
I get the exactly the same thing but on the way up! weird
no mine is on releasing the clutch but if I accelerate more its worse, ie just lift clutch nothing and seems worse on uphills when needing to give it more gas or when pulling off from a junction while turning.
Could it be an engine mount causing the manifold to touch the subframe??
