Clutch Problems
Car  Nippy white cup
Thought it was something to do with the gearbox at first but now I think its the clutch. When you go up to high revs, sometimes it sticks when you try to change gear, did a test and when I just put the clutch in, without changing gears, it acted like it was still fully in gear. Has anyone else had this prob?
Also grinds a little going into 2nd, just about makes it in to 3rd without totally crunching.....ahhh Renaults eh!
Ive been noticing recently that my clutch pedal has been coming up higher it also seems like the biting point is higher than it was then all of a sudden it goes back to normal?????????
Rob.
My clutch bites higher now, ever since I rammed it in fourth on the motorway to get some tw*t off my arse at 90MPH (changed gear properly just tooo quickly) I think it might have something to do with the cable, (theres a strange clicking noise as well), rather than clutch itself; am I right in thinking that if your clutch is on its way out it bites lower down, almost as soon as you try to release the pedal?.
