COBRA seat fitting
EVOgone
  Pink Cup Racer
OK got some Cobra Daytona recliners to fit. Now i need to know the folling this?
1. Do Cobra make (lower then std) subframes ?
2. What is the cost of the above ?
3. Is the seat belt fastener and tensioner detachable from the std seat, does it unbolt and attach to the new subframes ? (as i want to retian the std seatbelt.
Thanks for the help.
1. Cobra make subframes, probably have them ready made for a Clio. When i got my Sidewinders i had to have some custom made from Cobra, they were much higher than a stnd subframe though so be careful!
2. Thing they were about £40 to £50 each from memory, ready made ones were the same price aswell i think
3. Not sure.... wasn't aware that these actually attached to the seat. only to the same mounting points as the subframe i though?
  182>FRS>VX220 now 350Z
My subframes from Cobra are much lower than standard seats. (base mounted monaco buckets) Think they were £120 for the pair.
Are the daytona's side mount? If so then you will require different to what I have described above.
You're best off speaking to Gary at Seats Galore 01489 893081
Hope that helps mate
  clio 197 f1
just been fitting a set of cobra misano's tonight too my 182, bought a set of cobra subframes and bolted straight in with no problems, seat is a good 20-30mm lower than standard ones, got my subframes from demon tweeks, 10% discount for clio sport members, came out at £113 inc. vat and delivery
