code entering help
  ph2 172
No display for entering code on tuner list, done a search but what im after is the full sequence of entering the code from swithing the stereo on, if anyone could be so kind.
yes mate got the code just swapping from tape player but kangoo van hasnt got display. So just need blind instructions to input code.
anyone? or even is it poss to drop it into my car do the code and then quickly put it into my van or does it instantly lose memory and want the code again, if that makes sense.
Will lose the memory straigh away, therefor you must enter code again,
Can you disconnect it in your car,re-connect do the code and remember the sequency you did it then do the same in the van
Sorry if my English is not good.
Enter your 1st code by pressing switch "1", then 2nd code on switch "2", then....till 4th code.
After all, press & hold on switch "6" and u will hear a beep.
Is that what u asking? sorry if not :-P
