Coilover rear springs platforms?
  Charged Superleggera
if its the spring seat you are meaning then only need one at the top but you dont need the one on the bottom. just make sure you clean that area up and grease it so that the adjuster plate doesnt rust onto the rear beam
  SchwepTek™
Is it safe to completely remove the spring height adjuster on the rear to get the car lower or do i need some sore of platform?
  BMW M135i
As long as the springs seat in the raised section on the beam then there shouldn't be a problem. The rubber wants to go on the bottom if your not using the adjuster then.
