G
Gregor11
As per the title gents, what are the pro's and cons of coilovers on a Clio sport 172? Mainly used for a daily driver, may do 1-2 trackdays a year if that!!
Extra wear on the driveshafts iv heard? Cheaper ones can give a harsher ride and poorer handling, might have to do some hammer modifying to the arches too
I just put standard suspension on, car came with racelands, much much better now
it was the racelands i was thinking of getting as KTR are selling them off cheap!!
cheap coilovers = w**k and will ruin your handling
Buy H&R's and there are no cons.
no damping adjustment, no camber adjustment, over priced, dampers develop lots of play. I wont sell them
im on racelands for wee k now and only bad thing is exhaust on rear beam.ive been told raceland are same as ktec ones but i have no idea if its true.
this is my favourite post http://www.cliosport.net/forum/show...nd-%A3799.99&p=7787018&viewfull=1#post7787018
incorrect, doesn't have to be that wayOn the road they're quite harsh and bump, but that's pretty much the same with all coilovers.
are spax good springs? do they do progressive springs? im looking for good quality ride and lower it slightly, so the wheels fill the arch a bit more!! (i dont want it slammed!!)
do you do mail order?
not my first choice of springs, but they're ok. Better than Apex for example which are aweful. I like PI springs for a road car, 25mm drop, ride well and work with standard shocks. Eibach are good but they dont really make enough difference over standard to notice. Currently expanding our mail order service, so yes we can send out to you if you like, or if you want fitting of anything, we're only down the road from you
Bedford. Have a look in our traders section, got some fitted prices in sticky posts http://www.cliosport.net/forum/showthread.php?537044-Pi-Lowering-Spring-kits
Dan
got a car with a knocking set in the workshop right now. removed and returned numerous sets, identified knocks that multiple experts couldn't find and blamed on top mounts. Even removed some that had already been reconditioned once and one of the fronts had play in it again.i like you, but you do talk s**te sometimes :rasp:
Can get them within a couple of hours. Give me a call monday
no problem mate, if you dont hear from me monday, i'll call you first thing tuesday if thats ok?
So do Bilstein use cheaper seals on the inserts for the H&R's?
I managed to sort my exhaust knocking a bit with the socket fix (search it if you don't know it) might help yaim on racelands for wee k now and only bad thing is exhaust on rear beam.ive been told raceland are same as ktec ones but i have no idea if its true.
