All I know at the moment is that it is a v reg 1.2, I'm still learn all the different types as I have only had the car 6 days...
Yeah, don't quote me on this, but if it's a 16v engine and isnt the RS, it will be 58mm
For you, i would imagine you're looking at a set of budget Raceland/Rokkor/TA-Technix coilovers, you'll want to search on the forum to make sure you get the correct bolt spacing. you can also measure this yourself, it's supposedly possible to put the wheel on full-lock and get a ruler in behind to measure the distance between the 2 bolts. If it's 58mm - these will do the trick if you jsut want something cheap and cheerful. I have them in mine, the ride is obviously bumpier, but the car is nice and lower down.
http://www.ebay.co.uk/itm/COILOVER-...=Model:Clio|Cars+Type:1.2&hash=item3a8246c2d7
