R26
Only a few days into Clio ownership and the car packs in, ah well! As with loads of other people, emission light has flashed on and off, car is idling very erratic, misfiring on several cylinders all the time (its struggle to stop it stalling) and is totaly undrivable.
Reading threads, it could be coil pack, sparks, lamda or aching leads. Checked the leads, no problems that I can see. I am picking up a generic Coil pack that is sold as working on the 182 from GSF 2nite, if that solves that problem am I likely to see a reduction in performance? (Speaking from light aircraft experience, when using reserve coil pack it is massively noticable)
If coilpack brings no joy, where abouts is the lambda sensor and will unplugging it temporarily reset the ECU to using a default setting that, although burning wrongly, will atleast let me know if the sensor is at fault? (Worked whilst testing my old 320D)
Lastly, I will need to check the sparks, they look very hard to access needing intake manifold to be removed? Am i being blind or is this the case.
Many thanks and I will post an update when coilpack is changed!
Ben
Ben
