everybody keeps harping on about this supposed -14 degree weather coming in next week, if it does am I likely to expect anything play up on my car that anyone knows of?
No problems just make sure you tyres at at the right pressure as the cold weather leads to denser air so if the tyres were at the right pressure they may not be now. Also check you have enough windscreen washer mixture as you may need to run a higer mix to stop the water iceing up.
Your car should make more power thanks to the cold air.
One thing Id suggest is making sure that your battery connections are tight - we couldnt get the exs valver to start one morning, purely down to me not screwing the connectors down enough!
