Colour Code Help!
Can anyone help me out colour coding my new Clio?, i would like to know how to colour the black rubbing strips on the doors, and over the tops of the bumpers. do you have to remove the strips?, or can you just spray them where they are?, also is there any special paint to use because its plastic? or can i just use the spray paint for the bodywork on them. What about Primer?
i havent a clue and i dont want to fukk it up, please help Cheers
You need to take them off. Get some yellow filler primer + Grey primer + Car colour + Clear Lacquer all from halfords and you’ll need some wet and dry (800plus grit)
2-3coats of filler primer
rub smooth
2-3coats grey primer
rub down
2-3 final colour
2-3clear lacquer
rub down with 1500 grit wet and dry (soaked in warm water and fairy liquid) and then use T-cut and then Autoglym
