Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
I´m planning to put a 50 or 70 hp shot of nitrous (wet) on my clio 172. Since I don´t want to blow it up maybe I have to lower the compression, maybe 10.8 or something... The guys using nitrous what compression and nitrous dose are you using ?
You wont have to reduce CR for a small size shot like that.
Since a simple N20 setup is just a constant flow system, you can eliminate any damage by not firing the system before 3500rpm, this will minimise torque at lower rpm where damage can occur.
If you have a progressive system then you really dont have to worry at all even with 100bhp shots.
