Condensation but no damp patch.
  172
Last couple of days it's been reading and with the heater on my 172 has had condensation come back with a vengeance particularly on the rear Windows. The problem is all the carpets, headliner etc are dry. I can't work out where this is coming from.
I have thought there may be dampness often the Double skin of the rear quarters? How should I tackle this?
I'm thinking of stripping the entire rear interior to find this problem. Doors this sound like the best way to go our is there somewhere else I should be looking?
  172
Stripped one of back panels and the inside is full of grease. I've also noticed a small gap between the body panel and the wheel arch just where it begins. It's this normal?
  182cup & 172 racecar
Make sure your air recirc switch isn't left on, this can cause quite an amount of moisture.
Push the button on and off, you should hear a difference in sound when it changes over.
  clio 172 exclusive
I had exactly the same issue, made worse by my air con not working. Turned out one of my rear lights had a leak and my spare wheel was under about 3" of water.....
