condensation in headlight
Car  iceberg phase 2 172
hi guys i bought a phase2 172 so xenons etc , but its got condensation in the passenger headlight , any1 else had this an solved it ? i havent picked the car up yet so havent had a good look ...
Silica gel packets glued to a piece of string leave them soak up the moisture then pull them out a few hours later that should work, I was going to do it with mine
Yeahh leave it for a day or so make sure its dry if you do it though and then pull them out :)
I once had this and it was because there was no rubber bung thing at the back of the headlight that you take out to change a bulb, found one and put it on and the heat generated by the lights soon dried it out and hasn't been steamed up since.
It happens because a seal has gone on the lights. It will come back if you don't fix the cause.
Same problem, I was just gonna cut the glue and reseal it. But I'll give the little gel packet trick a go as quicker :)
Done use the Gell packs. I got two of them, tied it to some string and tripple knotted it
Guess what they snapped and i got one of the packs out but the other is stuck....
Headlamp is clear but the gell pack is still there! tried everything to get it out1!
LOL :P
But after a while the gel pack will stop and the condensation will be back.
You need to reseal the units to eliminate the problem.
mine was the rubber cap on back wasn't on right,
but what I did with mine was, take cap off, put headlights and full beam on, and set a hair dryer blowing into, also add a hot damp cloth over front. 10 mins later all clear :)
