coolant level in my clio 182
  clio 182
my coolant level keeps going down, i filled it up then checked after a 100 mile journey, and it was below minimum again.
the resevoir tank never actually empties completely it just drops to the bottom of the tank, i cant see any visible leaks and the oil is clear and not contaminated.
and there is never any warning lights on...
any ideas?
cheers folks...
  E36 Coupe & Mk4 Golf
Could have a leak fill it up leave it running and check for ovious leaks etc
  RS RIP
i had the same a couple of months back. My waterpump was leaking/faulty. Cost me a new pump (around 60 pounds) , new auxbelt and a little labour. In total 150 i believe
Next time when being able to look under the car you can spot a leak by the red (or green i believe) residue it spits out/leaves on other parts
  AGH the sl*g
keep an eye on your oil level in the engine if it increases the headgasket has gone.
  Dodgy one
I was going to say if it never drops past the bottom of the tank, One of the hoses to the tank may be leaking!
