Coolant, Silicone hose swap
Car  182 T
Hi,
Im running boost - 300BHP. I've got a coolant leak at a t-junction just underneath the air intake, I've not traced the pipework yet but Im pretty convinced the t-split is going off to the turbo. As I'm going to have to take it apart to sort it I was going to put some forge/samco hoses in.
Can I cut the 182 kit that they do? or do I need to go custom from the off? Will cutting them knacker the ends? I know I'll need extra for the turbo anyway. Are the silicone hoses very stiff? In pictures they look shaped which might be a pain because of all my extra pipework.
And do I need a new thermostat or seal or anything If I take the thermostat off?
Yes you will need to cut it and use a t piece to your turbo
I have Samco ones on mine but there all the same construction - Samco/forge etc
