Coolant
My coolant has gone down by about a quarter (gradually) from the Max level. Should I worry about this? And what should I top it up with? Looking at the Handbook it says that you have to get some special sort of solution from Renault, and this is all you can put in it... is this right?
  Trophy
Clare,
Should still be under warrenty, take it back to them and demand a top up as it shouldnt use any!
Mat.
Get them to take it in & do a pressure test, you should not loose coolant, it could just be a leaky hose or if your unlucky the sealant around the head gasket may have given up the ghost.
