right some1 has just mentioned to me that i should know about the coolant on a clio......its not just normal water/anti freeze, u have to get some special stuff from reno??? that right??
if so how much are we talking??? and how much is the normal stuff?
Coolant is normal as far as I know in a 16-Valve. Look out for leaks from around the radiator - like the bleed screw. I had a little leak at the bleed screw and a cracked header tank, but a little Radweld and a new tank have worked wonders.
