Clio 172 phase 2
Hello,
I am currently having problems with leaking coolant and overheating. So far it appears to be the rad at fault.
I have decided that id quite like to replace the whole system pretty much.
I believe I need an expansion tank, quite fancy a silicone hose kit, thermostat, rad, coolant and all the necessary clips/fittings.
The belts were done less than 2 years/15'000 miles as well as the water pump.
What other parts are worth replacing while im in there?
