Cornering lights
Car  Renault Clio Mk3 1.2
Hi
My cornering lights are not working,
Bulbs are fine but no voltage getting there, have disconnected battery, turned lights on and off numerous times to reset etc, car is new to me and initially they worked but stopped. Can’t find a designated fuse but have checked fuses under/ beside steering wheel and beside battery all fuses fine, car failed test as only one was working they said it was a dipped beam but there can hardly be two dipped beams rack side so assuming they are cornering lights. Very difficult to get too and behind a harm rectangular cover with two clips and s H7 bulb, any ideas would be greatly appreciated, fuse location, relay etc if they are there. Regards. Noel K
Worked then stopped then worked then stopped. Sound fine to me ?. What car is it mate and someone will give the location of the relay to check
