Correcting headlights
  Storm Grey 200
Do i have to use something like Plastx or will menzerna IP or FF do? This is after wet flatting them
C
clvs2222
same as paint mate, wet sand then with as light grade as you can (3000 megs i used) then using the rotary, IP then FF.
Had to sand mine down with 1800, To get the heavy glaze off mine. Followed by 2000 then 3000. Spent quite a bit of time with the rotary.. But they still need some work.
C
clvs2222
always start with the highest possible grit, then if your not having any success, change to a lower grit.
I did, Used a few grits. Had to resort to 1800 because it seemed to be the only thing working. They look fine.. Just a few swirls from the sanding which i will take out when the weather is better.
