corroded rear discs!!! warranty issue.
Car  172CUP/Fiesta supersport
after my front discs had corroded away to nothing on my 53plate cup 14'000miles I replaced them with brembo HC discs and greenstuff pads, then I thought right the rears are humped also but I don't want to have to replace these out of my pocket as they are expensive.So off I go to the dealers,they looked and said yes they are corroded!!!! (no s**t) and this was usually a warranty issue but because the car had only done 14'500miles they would not do it!!!! but if the car had done at least 7500miles per year they would replace them. So basically they are saying I have not used the car enough even tho it is used everyday altho not many miles....................Renault UK are getting a ring tommorow.
Good luck with that, you'll get the following reply I would expect...
Brake discs are a wear and tear item weather you use them or not.
Good luck with the call such a b**ch even if your under warranty they come up with the lamest excuses etc... been there before.
All the best with getting things sorted matey
yes but the fact that they have stated that they would change them if my mileage was higher is just incredible!!! IMO................if I had done say 15'000 miles this year it would be yes hears your spanking new discs sir,do come again.................or summit like that LOL.
To be honest I would expect the rears to have corroded after 3 years mate and only 14,500 miles.
thats normal, they all do it, its not a warranty item
change the rear pads (cheap as chips) then do a trackday, that'll soon clean them up!!
I had the same problem with my rears,kicked up a stink at renault and "as a good will gesture"renault changed them.My cup only had 12000 and was just 22 months old.
