Couple of issues!
Car  PH1 iceburg
Got a couple of issues with the car. The first is that the clutch pedal is sitting about 2 inches higher than the others. Could this be the clutch cable needs tightening?
Second is that under heavy braking the steering wheel vibrates alot and when slowing to a stop the car is jerking. Is this warn/warped disks?
Dan
Oh fcuk it im a tool.
Sorry its on a vauxhall mk 3 astra gsi? only on 52k! (if that makes a difference)
Dan
could well be worn discs, but there's a couple of bushes on those IIRC that can cause some braking wobble. Can't remember if the clutch is adjustable on those or not
