mgoode180566
172 Sunflower
Is this a first ?????
Lifted the broken engine out of the sunflower this evening. Suspect headgasket as lack of compression across cylinders.
As i lifted it out i noticed the aux belt not sitting correctly and pinched under the cambelt cover. Immediately i was thinking that it had jammed the cambelt and jumped the timing.
Always one for a mystery i cut off the aux belt and the ribbed part of the crankshaft wheel fell out on the driveway !!! It would seem that the crankshaft pulley is a pressed part and the outer had separated from the centre. Now this points back to an odd noise that had started some weeks ago when the car was on full lock. My guess is that under load the outer part was spinning but would track correctly at normal driving speed.
Anyone heard of this failure before ???
