LY R26 #288
Can anybody confirm the torque and angle setting for the crankshaft pulley bolt?.
In the F4R 730 manual it says 2 daN.m + 135 degrees +/- 15 degrees
and then later on in the manual when its showing you how to set the timing it says to do it up to 2 daN.m + 115 degrees +/- 15 degrees.
Anyone confirm what one it is?.
Also while we're on the subject I noticed that the torque for the timing belt tensioner isnt all that tight (2.8daN.m), do you guys use threadlock on the tensioner nut?.
Cheers.
Cheers.
