Crankshaft diameter
ripp
Car  182 FFAT
Hi there,
By any chance does anyone have a stripped engine or a 1*2 crank at hand? I need the crank diameter on the flywheel side, the area where the seal sits on the crank to be specific,
as far as I know it should be around 80mm.
Should be measured in 3 spots with a good caliper to make a precise average :)
Thanks!
Can't remember off top of my head but find a crank seal online and it lists the sizes of it.
it says the inner diameter of the seal, however i'm not sure that is the crank diameter also because the inner diameter of the seal expands when mounted
