My clutch pedal is making a loud creaking/squeeking noise when you press/depress it :S
Any ideas what it could be?
Cable is only £21 ish, will be a b*****d to do the first time you do it lol.
Didn't fix my creak though.
Grease or change cable mate thats what mine was
Same, had mine changed at renault. Was fine until I got some heat in the engine bay. Mine only creeks though when i've been for a very spirited drive. Not sure where the creeking comes from, but i presume it's the cable rubbing on something.
you can see it when you remove the airbox so follow it back to the bulk head and grease it where contact is made i guess.
Turn the radio up?
Still no cure for this? For the above reason ^ I don't fancy replacing the cable.
Creaking was really bad for most of today driven 140 miles - long drives & some spirited blasts included
There's only 36k on my car too
Where-abouts & what exactly was greased mate, do you know if it's easily done?
Easy to access, where abouts can you get at it to grease it up (guessing it's as simple as find & spray)
I sprayed some grease on it about a month ago from what I could see by peering into the bay but I've probably missed loads of it lol
Mine creaks alot, on mine its the knuckle that is in the center of the clutch release arm. They get dry which causes friction hence the creaking.
White grease, its pritty easy to get the straw nossel in there. its not the easyest of things to get too.Thats what mine is, any idea what to put on it to stop it drying out? Its quite a tight space to get too and I wary of getting grease on the clutch plate.
