Trafic 2 115dci 2009
Hi there,
I registered on this forum because I found a lot of good information regarding cruise control retrofit for Renault vehicles.
I retrofitted cruise control and speed limiter on a 2009 Renault Trafic 2.0 115dci.
ECU EDC16C36.
M9R786
All the buttotns have been installed: cruise control, speed limiter, plus, minus, pause and restart
I have activated the cruise control and speed limiter in the cluster instrument / UCH.
The speed limiter now works correctly. I can set the speed and it is shown on the display. And the car is not driving faster as long as the speed limiter is on.
But the cruise control does not set the speed. I can activate it and see the green light. But when the plus button is pressed, no speed is accepted. "The display stays at "SET ---"
I have already checked the following:
1. there are no errors in any of the 4 ECUs (Airbag, ABS, Injection, UCH)
2. Brake and clutch switches are OK (all three, checked with diagnostics)
3. All buttons are working (checked with diagnostics)
4. all fuses are OK
I also checked the following parameters with diagnostic tools, all look coorect and should allow cruise control.
UCH
LC119 Cruise control / speed limiter WITH
ECU
LC120 Cruise control LC120 WITH
LC121 Speed limiter WITH
ET042 cruise control / speed limiter REGULATE
ET413 Cruise control / speed limiter CC SUSPENDED
ET557 Disabled by CC / SL function INACTIVE
Is there anything I can still check or measure? Thanks in advance!
ECU EDC16C36.
M9R786
4. all fuses are OK
UCH
ECU
