Not silly at all I asked the same question to one of my mates off here a bit ago but as I didn't listen very well and havn't used it since I cant help lol
If you switch the little crise control button on behing the steering wheel (cant remember if its up or down though, as one is the speed limiter) then you will get a little green symbol showing, then press the R on the steering wheel it should set at the speed you are going. To slow it down, just press the + or - button on steering wheel. As soon as you break it will be deactivated, or I think there is an O which also deactivates. But I haven't used it for a while, so someone else will probably explain better, lol!
It is really weird, that's why I don't use it very often, only if there's no other cars about, otherwise I don;t really feel safe! It's fun when you have it set for quite a high speed on the motorway then deactivate it and it gets quite slow, then press the R button, as it accelerates back to the speed you was doing, but for some reason it feels really fast, probably because your not pressing any pedals, hehe.
