Cruise wiring at squib.....
  BMW M135i; Clio 172
I'm thinking of retrofitting cruise on a 172 with an aftermarket steering wheel. Does anyone know if I can I pick up the appropriate steering wheel connections from the loom behind the squib so I don't have to change the squib to a cruise one?
Thanks :grinning:!
  BMW M135i; Clio 172
I was thinking my car’s ecu already had the signal :pensive:.
Any way of telling?
  BMW M135i; Clio 172
Just reviving this thread now I’ve made more progress.....I have everything sorted including clutch switch, replacement esp/cruise/limiter on/off panel, and I’ve got the dash is displaying cruise “set speed” etc.
I’ve wired up 4 buttons with the appropriate resistances to control speed +\-/resume/cancel - but now I just need to connect these up! They won’t be steering wheel mounted, so I don’t need a cruise control squib.
So somewhere behind the squib should be a loom with the two cruise control wires. Any idea what colour the two wires I’m looking for are, and if they are bundled together on another connector? Any help greatly appreciated :up:.
  BMW M135i; Clio 172
For anyone who’s interested (apart from me :grinning:), the two cruise wires from the ecu terminate at the same plug as the steering wheel airbag wires. So I tapped into these (purple and black) and have successfully got cruise working without changing the squib :up::cool:.
  BMW M135i; Clio 172
sorry, thought i'd replied and said they were there.
Lol! That’s funny if you’re kidding, and even funnier if you’re not :laughing:!
Anyhow, if anyone in the future finds this thread because they need the info, I’m gonna look like a hero :tonguewink::smile:.
GrahamS
  335d, GT4
Cruise control is operated by putting 12v into one of the pins on the ecu, you then have those two wires which depending on resistance make the ECU do different things. 4 buttons work from the two wires.
  BMW M135i; Clio 172
I knows :wink:. I’ve made my own set of buttons with appropriate resistances based on your guide I believe :cool:, so thank you :up:. I’m gonna mount them in the panel alongside the esp/cruise/dimmer switches.
So reviving this, because I want to do the same thing...
I only need to enable cruise and have the speed hold function really so where do I need to feed 12v and what resistance do I need to switch accross the two wires shown?
