MrBlonde
I'll stick a load up in a bit :up:
I still can't believe I didn't fall in it, I was struggling to stay conscious at that point.Oh then these from my phone, little sing song with @Typhoon
@DaveDreads doing what he does best and out of the whole of Blyton park he throws up on same BBQ racks lol
View attachment 1331946 View attachment 1331947
Not a photo but my only session due to gearbox failure. Then having to limp it 70 miles home in 3rd
Good video mate, and gutted for you with the gearbox, looks like you where flying. What mods on the car? Managed a 1:18 myself, just didn't catch it on camera only on race chrono.
Thanks mate, yeah abit gutted as I spent the whole week fitting mods and preparing it but that's life I guess. I knew the box was near its last legs before I went but didn't think it would go. I've sourced another box so it will be back out again shortly.
It's got...
Standard induction with panel filter,
Catback mij exhaust,
Powerflex black series engine mounts (I need a vibra tech gearbox mount)
Powerflex black series arb bushes inner and outer,
Powerflex black series rear top shock bushes,
Powerflex black series exhaust mount bushes,
Whiteline rear arb (on hard setting)
Pms solid top mounts and brace setup,
Standard cup suspension with apex springs (I did not fit these)
Carbon Lorraine pads,
2118's with federal rsr 595 evo
Bms shifter,
Oreca 300mm wheel,
Custom cages full cage,
Sparco drivers bucket,
Fully stripped with trimmed dash (needs flocking and neatening)
Few other bits and cosmetic bits etc.
It's was running -0.5 camber front and 1.5 rear. I have the camber bolts and shims but eibach boxed the bolts wrong and I had 16mm instead of 14mm so couldn't alter it before but will be running -2 front and -2.5 rear for next time.
Mods I've got to fit..
Powerflex black series wishbone bushes non camber adjustable versions, rear beam mounts and steering rack bushes,
Pms rear axle spacers and -1 negative camber shims,
Eibach camber bolts for the front,
Odessey battery to be relocated inside the car,
Super blue dot 4 brake fluid change.
