cup shocks
  182 FF Arctic
just wondering are the cup 182 shockers the same as the std 182 shocker & was the cup pack just springs they changed?
Gaz_
  Extreme mode
Well the cupped cars have a different hub bolt spacing than a standard 182 shock, so they are different in that respect.
  182 FF Arctic
well thats what i thought but just spoke to nwp & they say they are the same, as my bro's rear one is leaking & needs new 1
Gaz_
  Extreme mode
says it all....
Non cupped 182 has a bolt spacing of 54mm
Cupped 182 has a bolt spacing of 60mm
You never said rear, (they bolt up the same) Cupped shocks are part of the 'extreme pack' Best thing would be to to check with Renault or someone in the know on here with a non Cupped 182 Reg and a cupped one. See if the part no's are the same...
  172/A4 Tdi
From memory I could almost swear that Koni only list one part number for rear adjustable dampeners. So I would assume they are the same - But definately worth waiting for one of the experts to reply first ;)
koi
  Audi S1
Pretty sure the part numbers for the cup pack rear shocks were different when I ordered mine, can grab the number for you later on if you want
