Cup suspension
Car  Clio 172
Iv got a clio 172 and was wondering weather or not you can fit the cup suspension parts to it? Also when throwing it into corners it seems to roll quite a lot. Is this normal?
Even the "Cup" set up rolls about abit through corners. I'd look in to upgrading to coilovers or use the current set up I have, Koni Adjustable dampers with Eibach Sportline springs.
Chears I'll have a look into that. Mine dosnt roll a bit it seems to roll quite a lot. It sticks well though.
Ooo How you getting on with them? Any pics :cool:
Handling is 10 times better, turn in is sharper and the back end feels more planted. Got them set on the hardest setting at the moment, it does get abit choppy and bouncy on really rough roads but the ride is no where near as bad as I thought it was going to be.
Haven't got any pics but the ride height never really changed from having the Sportlines on, it dropped at the most 5mm which isn't really that noticeable.
Should stay the same as its the springs that give it the height. Good to hear though, if i ever do tire of the Billies, its the way i'll go for sure. I've got the sportlines in the shed just incase ;)
The front shocks have put abit of camber on the front wheels as well. Well worth having this set up though, especially coming from standard shocks anyway. Body roll is pretty much eliminated and the car just feels so much more confidence inspiring. Thinking about the Whiteline ARB as the next step.
Although if you fancy swapping, I wouldn't say no to the Billies ;) haha!
