custom fuel rail
  182, 6r GTi
does anyone make these for the clio 172/182s ? in aluminium or stainless so you dont have to have the fuel rail gaurd on and maby adjustable fuel pressure to
thanks steve
  Lionel Richie
no need to touch fuel pressure at all
durability was the main reason (and ease) plus the added saftey factor - main reasons why the cup racers used them
  182, 6r GTi
do you know were you can get them or is it not realy somethink an average joe can get ? thanks for the reply
I think AT Power that sells their ITB product through Jamsport came with a billet fuel rail which had a threaded end to fix a braided line too. because the plastic OEM clip on mine was cracked by a trader when removing and blew itself off the fuel rail a month later. Id personally like a metal fuel rail which i can run about 100mm of braided line from then fix the braided part to oem hose using a high compression fitting. As Danny and Fred said it is pointless for the expence/benifit but its reasurance for me and gets rid of the plastic clip design. Oh and it looks the bollox!
  182, 6r GTi
thanks. the main reason is looks tbh and if i do hav a bump i dont fancy strugeling to get out of a burning car in harnesses.
