Bascially the car is fine wen its cold but wen it gets hot it starts hunting and cutting out wen coming to a stop etc, wen its being driven and underload its fine
i had a very similar problem on my old megane it was fine when cold but once it heated up and say i came to a junction put the clutch in it would die and cut out.
in the end the garage i had it from changed the vvt solenoid,coolant temp sensor and gave the throttle body a good clean it never done it again after that but it was only a 1.6vvt.
it could be down to a load of different things i have read a few threads on similar problems i will see if i can find some
