cv boot.. aaaaargh
Car  C1 VTR (Company Car)
If I hear knocking from my driveshaft do I still have time to get the boot changed to fix it or do I need a new shaft? If you know what I mean.
Also can anyone tell me how much I cafn expect to pay to get a new boot fitted? It's my outer one that has a pin hole.
Mine was destroyed but luckily I caught it in time, never had any knocking etc. I will probably fit a new driveshaft at some point though just for peace of mind.
as Dan says, if its knocking replace the CV joint. The Boot replacement is easy i have just done one on mine yesterday for its MOT. here are a few photo of the replacement.
remove bottom ball joint, and caliper ( to save breaking the line ) make sure you remove the 30mm Hub nut before you jack the car up.
I used a stretchy boot, if you use one you always turn it inside out. plenty of lube on the cone. but not on the part your pulling :)
you will need, 18mm Socket and ratchet 30mm Hub Nut and a cone, WD40 and a new boot with grease oh and its messy!!! :)
