Damn immobiliser fault
  Ph 2 172 Track Car
Hi All,
Car will turn over but wont fire! Immobiliser light either stays on solid or flashes.
Can anyone recommend an auto electrician or someone with CLIP local to Newton-Le-Willows, Warrington area?
Want to find out exactly what the problem is.
Cheers!
  dan's cast offs.
you tried the usual leave the ignition on for thirty seconds or so and see if it clears?
  Ph 2 172 Track Car
Yeah, tried everything listed in the posts on here.
Hence auto electrician, need to know if it's a broken wire/immobiliser fault/ whatever it is?!
So annoying. Went to the car this morning and it was fine!
  Monaco 172 + mk1 RSi
Did you find someone with clip dude? I'm local to you and looking for someone to plug mine in as I have an immobiliser fault also:/
