Dash foglight comes on when press brakes
R-Sport.
  Mint 1*2's for sale-
I know this has been covered before- when I hit the brakes on the 182 the foglight flickers on the dash
I think its corroded connectors-
what ones need cleaning
thanks in advance
S
  Audi A5
Most common cause of this is the connector and light cluster pins on one of the rear light units.
Best bet is to remove them and have a look, if their really corroded it will need a new cluster and connector, if not too bad then you can try cleaning up the terminals and see if the fault stops.
R-Sport.
Cheers-
Its been so long since ive a had a cluster off- is the pins on the wiring block on the loom or in the lights-
S
Rob
It's generally the female side within the block on the car's end Steve.
Pull the clip on the plug remove them all individually and give them a quick once over with wire wool. Quick go over of the cluster with a cotton bud or similar to dry it out and it'll be sorted.
MRBILLYUK
  FF Jeden Osiem Dwa
I checked mine the other week because i was getting the flickering foglight symbol on the dash , but my connectors were like new in both clusters . I think mine was just moisture , i sprayed them liberally with WD40 and that sorted it for me .
