Hi mate could you explain the ( cycle thru to the error code screen ) having a blonde moment cheersClockset in to test mode, cycle thru to the error code screen, press and hold the trip reset, key off and all should work again.
Ok cheers mate I will give it ago tomorrowYou got it into test mode ok? By holding in the button on the right stalk and turning key to ignition.
It'll start beeping and the clocks will go through their range test.
Press the button on the end of the stalk (can't remember how many times) to get to the error code screen.
Then hold in the trip reset button.
