Dash lights going crazy?!?
Car  2003 Clio 2.0L 16v
Hi.
I have a problem with my 2003 Clio 172.
When I press the brake pedal the fog light lamp on the dash comes on for a split second. Sometimes it stays on for more then a split second but never very long.
Also, Sometimes during hard accelration 2 lights in the middle of the dash light up (cant really say which since it only happens rarely and I dont notice what are the lights). It is not the traction light for sure.
Is this a faulty ECU on its way out or is it just bad wiring? Thanks!
OMG.. I've just started getting this exact same issue. When I apply brake pedal, sometimes the rear flog light indicator on the dash flashes for a split second. I don't get the other two lights you mentioned though.
Did you find the answer?
I'll check rear earth.
MATT BLACK, check the UCH? You have me worried. You mean the UCH fuse?
