The service light doesn't mean its due for its service . It means there is a problem with the car and as you say the airbag light is on as well so there's your problem . Its usually the wire for the airbag under the passenger seat . Just give it a wiggle and it " should " go off .If that doesn't work wiggle the wire under the drivers seat . Nothing to worry about mate it's a common problem .
