took me a day but could be done in a couple hours if you hammered in to it, i bought mines at crazyleds.co.uk, cheap and perfect, good guide with it as well, includes evertything you need (window switches etc) the dash is SMDs (small LEDs) and ye need soldered
i wouldnt call it simple, but its do-able if your the type that can change your own oil etc lol, it was the first time id soldered anything, the guide is step by step in detail
well depends how driven and competent you are lol! a pro could probably do it in an hour ish, it took me all day but i was pissing about and painting interior plastics too so ... how longs a bit of string you know?
I did mine today, I've never soldered in my life and it took me a day lol, the thigh that took most time up was getting a good connect to the board then going outside checking if they work etc. Now I can't get my dash back in
Nah I just done the dials lol And it took me that long I haven't got anything to take a pic with at the min mate but it's definitely worth doing, might do the heater controls next anyone know how hard it is? Soz about the highjack
easy peasy its just 2 twist in bulbs at the back, radio is hardest (i thought) then dash, everything else is easy peasy except poss climate control, dont know because cups ftw lol
pop off the bit of plastic underneath, then the bit of plastic between the heaters and the radio, then you should see 2 torque screws under this second bit, remove them and wiggle it out! easy peasy
