I have a clio dci, and its started losing power when i give it more than half throttle and go above 2500rpm. When it does this the engine managment light flashes. I plugged it into a diagnostic computer and the fault code says, common rail fuel pressure function. Spoke to renault and they said clean the egr valve and try it, if its no better cut the old fuel filter open and if there is metal filings in then the fuel pump is knacked.
Has anyone had this fault/problem, justed dont want to buy a pump and be something else?
cleaned the egr valve and it was no better and there was a small amount of metal filllings in the filter
