**de-cat Pipes**
This what was said over at F7power a while ago, i have no reason to doubt it, may have been ChrisH that had done it
I have a valver de-cat on mine but my whole systems custom anyway. The decat pipe is longer than the cat it replaced. You could get it to fit but you might need to do some cutting and welding
1.2/1.4 decvat is slightly longer (20mm) than the 16v/williams
1.2/1.4/16v flanges are 90 degrees to each other, williams is 45 degrees with a larger downpipe flange
