Dead Radio.
  Clio Campus Sport
:S My radio has died in my Clio Campus Sport 07. The clock is permanently on and will flatten my battery. Is this a known fault. Please help.:(
Died how? Are you sure you don't just need to enter your code? The clock won't flatten your battery.
Sam
North East
You mean permanently on when the cars not running ?
Thats probably an ignition live fault, not a radio fault.
  Clio.
There used to be a problem a couple of years ago where the radios would get affected by very cold weather, disconnecting the set would reset it.
  clio 172 phs 1
Yep this is a known fault, we used to be changing radios all day long in the winter.......! It's a known fault but like said above, if you disconnect the set and plug it back in it will work again.
