I have a 2002 clio sport 1.6 and want to remove the clio badge from the back of my car.
Is the badge just stuck on or is it actually drilled onto the car?
Would it be a simple procedure to remove it or would it be quite costly?
drilled into the car (i know this cos i rolled my 2000 clio and managed to rip the badge off somehow??), its do-able, but will probabbly cost you a bit
If its anything like a 16v theres holes in the boot for pins in the badge. I took mine off last week, and put some metal plates behind the holes for now, bonded on with metal loaded epoxy. (should be welded really i think) After that just get a body shop to fill over the little recesses rub it down and paint. Shouldnt cost too much, and gives the car a smoother look.
