Decat help!
fairly sure thats only got the sleeve on it for the ktek ultra performance. Your exhaust is 2.25 same as mine so it would need the reducer sleeve which i think ktek supply with the ultra performance exhaust so you can fit it onto standard cat? However if depends if that decat pipe is the ultra performance 1 or the standard fit one.
Give ktek a message on here first.
If it doesn't fit, it can be made to fit with the sleeve mentioned above. It's fairly cheap IIRC.
how much you paying for it? nwperformance ones are only 50 quid brand new and fit onto my ktec perfect.
