Decat question
Car  Inferno 182
Probably been said before but I can't find it. Can you use other branded de-cat pipes on an aftermarket 182 exhaust. I've got the ktec ultra system and need a decat to fit it, but struggling to find a cheap used ktec one.
any decat that uses the olive joint should fit iirc as ktec actually supply the sleeve to fit it onto the standard cat which uses an olive joint.
ive got a ktecsupersport and it came with a little sleeve adapter to attach it to my standard cat using the olive joint but the decat i ordered with it also slides straight into my center section without any adapters.
