Hi, need help and somone to shed some light on this.
Lastnight my injector fault warning light came on for the first time, not knowing what the light ment I pulled into a lay-by and had a fiddle around. After about 10 minutes started the engine back up and the light went out and the car seemed to start fine and run fine to get it to my girlfriends house.
Had the car plugged into a diagostic system which gave me 6 error codes. im unsure as to why it gave me injection warning light when none of them are directly linked to the injectors themselfes? ive had no running issues before hand?
2007
Throttle-valve position sensor plausability
3503
Fuel evaporation regeneration valve open circuit
(ive removed the carbon canister over a month ago and blanked up the pipe leading under the car to the fuel tank, if thats got anything to do with this.)
3623
Solenoid val. var.-tract int. manif. open circuit
(ive removed the acoustic valve over a year ago without any issues)
3913
Cooler fan stage 2 open circuit
5517
Brake pedal switch plausability
5516
Brake pedal switch malfunction
2007
3503
3623
3913
5517
5516
