help with a few faults
Car  monaco 172
Just took my 182 in to quick fit for some faults read as my abs and traction control light are stuck on.
First fault was Rear right wheel speed sensor which I'm guessing is the abs sensor. I'm thinking that's a pretty easy fix, I followed the rear sensor cable back and it seems the wire is really long and it doesn't split to a plug until near the hand brake cable join half way down the car unless I'm missing some thing.
Next fault was Brake pedal switch malfunction/plausability.
And also Solenoid VAL var Tract int Manif. Open circuit...... What the hell is that lol?
I'm guessing the first 2 are easy fixes but the third one I haven't a clue what it means.
Well I've just adjusted my break pedal switch and it seems perfectly fine so I'm guessing its not that.
Anybody?
I've also noticed a slight grinding/bumpy feeling on the break pedal when I press it while the car is moving. If I press it stationary I doesn't happen.
Possibly could be a mix of faults so you might have a faulty abs sensor on the rear and a snapped abs Ring on the front...
Or could just be a poor pick up on the rear or the abs sensor needs cleaning !!!
Could be anything lol
