Diesel Fuel pump
having a little trouble Fuel pump isn't sucking at all. If I took the stop/start valve out would you expect fuel to piss out of the hole ??
There was a blockage in-between the Fuel line in and the bleed nut.
So put 200 PSI of air into the fuel line and :) yaya UN-blocked
